Re: 6V conversion
Posted by Bob M on April 01, 2003 at 06:11:56 from (165.170.128.66):
In Reply to: 6V conversion posted by Nadz in PR on April 01, 2003 at 05:32:01:
Best plan would be to take the M starter to a competent starter shop and get it rebuilt. Also have the shop put a NEW manual starter switch on it. Get rid of the existing battery cables, and the starter solenoid if used. Install new #0 or larger cables with soldered (not clamped) terminals. Doing all the above, and installing a new 6 volt battery will make your M start like new! For the ignition, if the coil circuit had a ballast resistor added when it was converted to 12 volts, get rid of the resistor. Or if a "12 volt" coil was used, you'll need to replace the coil with a new 6 volt coil. Finally if the original generator is still in place, installing a new 6 volt regulator and polarizing the generator will take care of battery charging issues. However if an alternator or a 12 volt generator was swapped in, you'll need to get rid of the alternator or generator and replace with a 6 volt generator and regulator. Also if the tractor is now wired up negative ground, you'll need to swap the connections at the ammeter - otherwise the ammeter will read "backward" on 6 volt positive ground. Good luck!!
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
