Re: carb adj
Posted by Wayne Swenson on April 02, 2003 at 20:28:17 from (66.228.233.112):
In Reply to: carb adj posted by Dave on April 02, 2003 at 18:43:06:
If you had the carb off, is the governor peg in the notch where it connects to the carburetor??
If you took the throttle valve out for cleaning, is it correctly centered again? Being off center or upside down can cause a fast idle.
The screw positioned right where the governor connects to the carb is the idle RPM adjustment; back it out to slow the engine down.
PLEASE DO NOT FORCE THE MIXTURE SCREWS TIGHTLY INTO THEIR SEAT; DAMAGE WILL OCCUR!
The other screw located higher on the carb is the idle mixture (low speed) screw. Start at about 1 1/2 to 2 turns out then fine tune after the engine is warm and idling @ 450 RPM.
The main jet (high speed mixture) screw is on the bottom of the carb; try 2-3 turns out to begin with. Adjust when warm by running at fast idle (wide open throttle), turn the mixture screw in slowly until the engine begins to slow down(lean mixture), then turn the screw out 1/2 to 1 turn. Turn the screw out too far & the engine will begin to smoke & slow down also. That mixture is way too rich! Half way between too rich & too lean is good.
Now idle down & recheck the low speed mixture and idle RPM's.
Having fun yet?? Enjoy!!
Post A Followup
: Re: Re: carb adj
Today's Featured Article - The Day Tractor Lovers Dream About - by Angus Crawford. The day started at five o'clock on the morning of Friday, the January 29, 1999. My father, my sister, my uncle, my cousin and myself all climbed into my uncle's Toyota van. It was six thirty in the morning and we had a long day ahead. We traveled for six and a half hours to our destination - a little country town with a population of no more then one hundred and fifty people (57 of them being children under the age of thirteen). We arrived hoping to meet up with a man we knew had over one ... [Read Article]
