Re: Very technical TA question
Posted by Red Rider on April 03, 2003 at 20:14:32 from (66.248.123.56):
In Reply to: Very technical TA question posted by Tim Malin on April 03, 2003 at 18:22:31:
Tim, When you pull your TA lever back to run on the low side you are running the power through the planetary gear set. When this happens you are opening the TA clutch their by releasing the TA assembly from the torque of the engine. The natural response of the TA assembly is to turn backwards. This what the over run clutch is for (ramp and roller) to lock the TA assembly from turning backwards. Now the reason your tractor will coast when on the low side is the over run clutch only lock the counter rotation not the clock wise rotation. If the TA assemble had some sort of hydraulic brake mechanism that clamped the TA assembly solid then it would not free wheel. My opinion for the reason IH did not do this is to keep people from over running the engine. Imagine running down the road in 5th gear at close to 20 mph and pulling the lever back to the low side. It would either overrun the engine, slide the tires or throw you over the steering wheel.
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
