Need help with pto shaft replacement on a B
Posted by Dave_D on April 04, 2003 at 11:32:03 from (206.176.131.27):
third party image
I finally got around to replacing the bent PTO shaft on my 1942 B. I purchase a pto unit from a C to replace it with. Turns out, its not the same. So a simple R&R is not going to be possible. It does appear that I should be able to remove the PTO shaft from the C housing and put it into the B housing. I see the gear is pressed on to the pto shaft, does this have to come off to get the shaft out of the housing? And advice would be greatly appriciated.
Did fine an interesting trick, note in the picture the string used as a gasket. It was used with silicon also. It was a good tight seal.
Thanks
Dave D
Chico, TX
Post A Followup
: Re: Need help with pto shaft replacement on a B
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
