Re: Need help with pto shaft replacement on a B
Posted by ThatOtherGuy on April 04, 2003 at 18:30:54 from (65.43.32.143):
In Reply to: Need help with pto shaft replacement on a B posted by Dave_D on April 04, 2003 at 11:32:03:
Had the same problem. It seems the newer style PTOs (above 1948) have different gears and the engaging clutch shaft is completely different. I also know...I tried to get a PTO from my 1954 Super A1 to fit my 1945 A. (the Super A1 has a badly damaged engine from frozen water.)I also found out that a early 40s A PTO has a different gear train.
I think the gear might have to come off...I cant remember. Also check the PTO shaft itself is the same size or it wont work...
So Im stuck with a busted PTO housing on my 45 A and have two different ones that I might not need.....
Post A Followup
: Re: Re: Need help with pto shaft replacement on a B
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
