Re: IH 966 Hydro transmission slipping under load
Posted by Bernard le mécano on April 05, 2003 at 22:36:06 from (142.169.55.45):
In Reply to: IH 966 Hydro transmission slipping under load posted by Tom on April 02, 2003 at 19:19:40:
Hi Tom, is the tractor stop in reverse to? Is the power-steering OK? May be the foot-n-inch valve leak or pressure adjustement to low or return pedal spring bad. Or a bad charge pump. Check the charge,servo and high pressure. You may cap the two small pipe at left side of the transmission, there from relief valves.Run the tractor not to hard,if it's good, the drive contol or the foot-n-inch valves are bad, if it's not good, the problem is in the transmission. High pressure relief valves works at 5000 psi, charge 80-150 psi, servo 235-250 psi.
Bernard le mécano
Post A Followup
: Re: Re: IH 966 Hydro transmission slipping under load
