Re: Re: M jumps out of 5th gear
Posted by justin on April 09, 2003 at 19:59:19 from (216.188.198.180):
In Reply to: Re: M jumps out of 5th gear posted by Bryce Andreasen (Magnum) on April 09, 2003 at 19:55:10:
I forgot to mention what bryce did. one way to check the front transmission bearings is to take the belt pulley or cover plate off and see if you can lift the main shaft upwards. This will usually give you some indication as to the condition of the bearins.
Post A Followup
: Re: Re: Re: M jumps out of 5th gear
