Diesel governor
Posted by Brad Rackers on April 14, 2003 at 08:08:23 from (65.215.148.254):
I have a IH 574 which I purchased within the past year. At one point last summer I was running a brush hog and the tractor began surging over and under the RPM setting. It would swing about 300 rpm. Now days it doesn't seem to be running quite right.
I checked the fuel system and now I'm wondering if the governor is working properly. If I run in gear with the throttle about 1/2 open and begin up a hill the engine doesn't maintain speed. I know theres plenty of engine left since if I open up the throttle the engine will speed up but the way I understand it, the governor should take care of this automatically to try to maintain the set engine speed.
Any ideas??
Thanks,
Brad
Post A Followup
: Re: Diesel governor
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
