Re: Farmall M oil check?
Posted by Larry in CO on April 14, 2003 at 15:37:35 from (32.97.110.142):
In Reply to: Farmall M oil check? posted by Josh on April 14, 2003 at 08:03:31:
One other suggestion: You can get replacement valves from your local CIH dealer for about $8 or $9 each. They don't look exactly the same as the original ones, but they work the same. Also, if you want to keep the tractor original, you can find the original check valves on eBay pretty regularly. HTH Larry
Post A Followup
: Re: Re: Farmall M oil check?
