Farmall Tractors Discussion Board
need wiring diagram for voltage reg. on Intern. M
Posted by Dave on September 13, 1999 at 07:53:40 from (208.150.193.131):
4 cyl; gas; 6 volt positive ground; need help wiring voltage regulator to generator and ammeter. The Red sent jpeg pictures but my voltage regulator is different. Has two terminals on outside (right side) and one terminal on inside (or left side ) of voltage regulator. The two terminals on gererator are not labelled as to which is the field post and which is the battery post. The ammeter shows discharge in "ON" position AND with engine running.
Post a Followup
: Re: need wiring diagram for voltage reg. on Intern. M
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
