Farmall Tractors Discussion Board |
Re: need wiring diagram for voltage reg. on Intern. M
Posted by Village Blacksmith on September 13, 1999 at 12:14:15 from (205.188.199.53):
In Reply to: need wiring diagram for voltage reg. on Intern. M posted by Dave on September 13, 1999 at 07:53:40:
Our "H" has a "regulator" exactly as you described, only if you take the cover off, it is only a relay. You might check for sure. After brushing off the dirt, it did have labels on all the terminals, although somewhat dim.
Post a Followup
