Re: 1586 Transmission Problem
Posted by RAS on April 18, 2003 at 16:41:56 from (66.87.12.37):
In Reply to: 1586 Transmission Problem posted by charlie on April 18, 2003 at 16:28:34:
Remove the starter and cover, check to see if the rollers are still on the cam. If all looks good check to see how much play between gears. The 3 speed is different from the 4 speed it has shims to set end play on the gears. Hope this helps.
Post A Followup
: Re: Re: 1586 Transmission Problem
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
