Re: Need help on fuel system on IH 1486
Posted by Mike on April 18, 2003 at 20:17:04 from (208.188.178.162):
In Reply to: Need help on fuel system on IH 1486 posted by Farmall Farmer on April 18, 2003 at 19:27:17:
It sounds bad there is a transfer pump on the back of the injector pump,it's where the two lines go into the back,some times these will strip the little drive coupling/and or shaft.BUT first take the three bolt cover on the side of the inj pump,and see if the delivery sleeve will slide up and down,if so and it will run on ether it's probably the transfer pump,and it will need sent off to a diesel shop
Post A Followup
: Re: Re: Need help on fuel system on IH 1486
