230 With Pipe Loader Won't Fully Bleed, Why??
Posted by Drizler on April 20, 2003 at 18:07:41 from (12.107.140.100):
I have a 230 with what seems to be an OEM 3' pipe loader powered by the hyd pump under the tank. Last Fall I busted a line and never could get the darned thing to fully raise again. It went up 4' and I thought it would eventually work itself out but just got worse again. I tried parking tail down on the hill to get the rear hitch going and have since worked the hydraulic dump lots and spewed hydraulic oil all over the place getting that far even. Is it easier to open a line up on the loader arm to fill and bleed it as the square headed recessed plug in the top of the pump doesn't make for easy access. Am I going to have to shove that loaders arms to full extension on something manually to get this full? At present it lifts to 3', both the hydraulic dump and rear hitch work fine. HELP!!!
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
