Re: Re: Farmal Cub Timing
Posted by Don on April 22, 2003 at 15:19:52 from (206.31.97.19):
In Reply to: Re: Farmal Cub Timing posted by George Willer on April 22, 2003 at 14:14:02:
I found another timing mark on the pully, so it has a total of two, about 10 or 15 degrees apart. And it has a spark coil. Is one of them the TDC and the other the full advance? Can I just use a timing light, get it started and crank it up and adjust the timing to the advance mark with a timing light?
Post A Followup
: Re: Re: Re: Farmal Cub Timing
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
