Re: need to clean hydrolic screen on 300 utility
Posted by LanceM on April 22, 2003 at 17:57:28 from (216.241.137.123):
In Reply to: need to clean hydrolic screen on 300 utility posted by mike on April 22, 2003 at 14:38:27:
You have to pull the top of the tank off. Not a hard job just heavy. Take the valves off, take the seat off, remove all the bolts holding the top on and lift it off, the screen is attached to it underneath so don't set it down on it. The lid is real heavy so have help. I found my screen collapsed from being clogged. New ones are available and not that expencive. Clean the tank out good while you have it open and then reassemble. Of course drain the tank before you start!
Post A Followup
: Re: Re: need to clean hydrolic screen on 300 utility
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
