Re: Re: need to clean hydrolic screen on 300 utility
Posted by dick on April 23, 2003 at 08:23:40 from (65.58.58.212):
In Reply to: Re: need to clean hydrolic screen on 300 utility posted by LanceM on April 22, 2003 at 17:57:28:
Lance gives a good description, but I'll add a caution - if you don't lift the top STRAIGHT up, you can count on wrecking the screen. Plan what you're going to do with the top before you remove it - the screen sticks down below the gasket surface, so you can't just set the top down anywhere. This is not one of IH's better engineering jobs.
From your description, the screen is probably collapsed already. A new one runs about $80.
Good luck.
Post A Followup
: Re: Re: Re: need to clean hydrolic screen on 300 utility
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
