Re: Throttle positioner on a C
Posted by Hugh MacKay on April 25, 2003 at 02:28:44 from (216.208.58.97):
In Reply to: Throttle positioner on a C posted by DaveK(IN) on April 24, 2003 at 19:21:51:
Dave: One would have to look at individual lever and plate. On my SA and 130 the lever was worn. I built it up with weld then ground it off to right shape. I also found the spring weak. This of course was what allowed it to slip over the teeth on plate in beginning. The wear was the result rather than the cause. Just pick up a new spring from CaseIH. It will soon tell you just how bad old spring is. The teeth on plate must be in good shape also. One of mine needed a new plate. I make a point now of lifting lever away from plate when advancing lever same as you have to when slowing down. My reasoning is I'm willing to bet new plate will not be the quality of the old one.
Post A Followup
: Re: Re: Throttle positioner on a C
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
