Re: Re: Re: Re: Throttle positioner on a C
Posted by Hugh MacKay on April 25, 2003 at 04:55:35 from (209.226.247.91):
In Reply to: Re: Re: Re: Throttle positioner on a C posted by Harold Hubbard on April 25, 2003 at 03:55:00:
Harold: Thanks on that one I must admit I didn't delve into the lower part. I know my lever is fine as it rlates to actual wear, however the one that still gives trouble is the one that still has old plate. When I hold my SA and 130 lever up side by side they don't look quite the same. SA lever is straight. 130 lever looks as someone pushed lever about 3" from plate not only putting a curve in it from top to bottom, but it appears twisted as well. I don't think this ever happened on tractor as the pin and spring assembly would never stand that. There is a possibility the lever got awitched with another tractor as I had 2 of them apart in shop back a number of years.
Post A Followup
: Re: Re: Re: Re: Re: Throttle positioner on a C
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
