as the dirt turns....(or the 140 is alive again!)
Posted by Mitch in NC on April 25, 2003 at 14:01:24 from (209.215.45.88):
Just over a year ago, I became the proud owner of my first tractor, a 1962 140. I was in Farmall heaven. I commenced t'breaking ground and planting veggies. Soon after that, due to my ignorance (which is a whole 'nother story), an old crack in the block reopened and left me with an acre of vegetable seed in the ground and no tractor. Now, an acre don't seem like much, but it's a whole lot more than I wanted to do with a tiller and 5hp mule plow. Anyhow, I studied you guys' forum for a year while I anxiously awaited this years income tax refund. What a wealth of information! Now, keep in mind that I'm not a collector or restorer....I just needed a good veggie tractor. As grace would have it, I met a local guy with a 140 that had been driven into a canal 4 years ago, busting off the front end. My new friend sold me his complete engine for $500. So, never having worked on a Farmall before, but reading from this forum, my son and I had a wonderful time switching engines, replacing the clutch package and rebuilding the steering box (which had over 1/2 turn of slop initially). Now, all my land is planted, and I can hardly wait to begin cultivating and side-dressing. I just wanted to share with you guys a few things learned from this experience. Maybe someone else might benefit from it. 1 - As anxious as you may be to get your tractor running, take your time and think repairs through first. Be safe, price things from several places, and be sure that you actually need what you think you need. 2 - If you aren't sure how to do whatever it is that you're fixin' to do, ASK QUESTIONS! You can do a lot more damage sometimes if you don't know what you're doing. I learned a long time ago that pride is a costly item and humility is cheap, if not free. 3 - There are at least 3 plates on the C-123 engine that are not flat and need sanding to seal properly. I found that the rear crankshaft oil seal retainer halves and the oil pump bottom plate had to be sanded. Place a piece of 100 grit paper face up on a hard flat surface, and sand the flat side of those parts down, working your way up in grit until you get a true surface. You can true these surfaces up with not too much trouble, but I believe they will eventually leak again if you don't. Doing the pump bottom alone brought my oil pressure up from 25 to 60 psi. 4 - And most importantly. Fuel, Fire (at the right time) and Compression! I could not get that 6 volt Farmall to crank and run good for 2 whole days. I would come back and re-read what I had already read. Fuel, Fire and Compression. Ended up setting/checking timing over and over, replacing the plugs, points, condenser, rotor and cap, removing/switching carbs 6,000 times, cleaning out tank and installing an inline filter, but it sure was satisfying when she revived! All that stuff didn't cost alot anyhow, and would've needed changing soon anyhow. I ended up rebuilding the Zenith and replacing the coil to get the soot out of the exhaust, but that was after the tractor had been working for a couple of weeks. I know this was long, but there it is. And it didn't cost ya a dime. Come see us. Mitch
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
