Posted by Jeffrey Muehring on March 29, 2009 at 17:30:58 from (209.240.206.202):
This H is gettin me down. I did as some suggested and took carb back off. I sprayed all passages out with carb cleaner and adj float so gas will be higher. Same story, it only tries to start if Im spraying sarter fluid in air intake. Im going to take a compression reading , maybe new rings not being seated is causing compression to be to low. The old H spins over real fast with 12 volt but has high dome pistons. Appreciate all the responses.Jeff.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
