Posted by CNKS on March 29, 2009 at 18:09:09 from (216.144.104.128):
In Reply to: H still wont start. posted by Jeffrey Muehring on March 29, 2009 at 17:30:58:
El Toro and Jim are both correct. And, if the manifold is not tight, the compression test will not be correct. If you have a rebuilt engine, disassemble the carb and soak it overnight in real carb cleaner, as the stuff you are using probably won't do much. Blow out with compressed air. Put a new kit in it. First check the carb inlet with your hand to make sure the manifold is tight. You would have to do an impossibly lousy job with the rings to get compression low enough to where it would not start -- very doubtful.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
