Re: IH 464 hydraulic problems
Posted by Ben in KY on April 27, 2003 at 19:18:32 from (209.209.158.72):
In Reply to: IH 464 hydraulic problems posted by Jason on April 27, 2003 at 18:40:24:
If the hydraulids worked fine after "bleeding" some fluid out like you said, then your pump may be sucking in air somewhere in the suction line to the pump.
Post A Followup
: Re: Re: IH 464 hydraulic problems
