Re: Extra wheel weight for Super A-Which side???
Posted by Shaggy on April 27, 2003 at 21:03:37 from (12.215.124.74):
In Reply to: Extra wheel weight for Super A-Which side??? posted by Gav-n-Tn on April 27, 2003 at 20:21:36:
I have a wheel weight on both sides of my Super A. The right has the heavy cast iron center plus a weight and a steel center and a weight on the left. I am plowing with a 2 12 plow and thinking about putting a extra weight on the left. Maybe this helped you a little.
Post A Followup
: Re: Re: Extra wheel weight for Super A-Which side???
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
