Re: 400 diesel only two hydraulic levers
Posted by Red Rider on April 27, 2003 at 21:07:57 from (66.248.102.106):
In Reply to: 400 diesel only two hydraulic levers posted by jake on April 27, 2003 at 07:54:36:
A Farmall 400 could be ordered with one, two or three hydratouch valves. As for power steering, putting the factory set up on it will require changing the regulator valve as well as the first hydratouch valve. If you use a seperate hyraulic pump then I don't know. There is not a lot of room to mount an independant pump or mounting brackets for it. The factory power steering works through your tractors hydratouch system.
Post A Followup
: Re: Re: 400 diesel only two hydraulic levers
