Farmall Tractors Discussion Board
Re: Re: HELP!! My tractor won't run- carb flooding
Posted by John Schnaubelt on September 14, 1999 at 20:08:53 from (216.145.159.43):
In Reply to: Re: HELP!! My tractor won't run- carb flooding posted by ltf in nc on September 10, 1999 at 09:53:07:
The responder who suggested the simple U-tube manometer to check float level is a genius ..... I sure liked his idea. I am adding this in case you may have overlooked the simple ..... I have had the same problem on Farmalls thru the years. It is the float valve sticks or just doesn't seat. Replace it with a basic overhaul kit. Or, turn the fuel valve off and try starting it. It should run when the fuel works its way down to the proper level in the carb bowl. sometimes after it is running, the vibration will get the float valve freed up and working again.
Post a Followup
: Re: Re: Re: HELP!! My tractor won't run- carb flooding
