Re: Setting gap on 560D tappets
Posted by Steve - IN on April 30, 2003 at 04:09:02 from (12.222.17.59):
In Reply to: Setting gap on 560D tappets posted by RO on April 29, 2003 at 19:21:28:
RO, I've never worked on a 560, but some general advice should work, as they're basically the same. Start by putting the #1 cylinder at piston Top Dead Center and adjust the lash for the two valves in that cylinder in that position. There will probably be some other valves ready to be set at that position, and you may want to get a service manual for the sequence instead of noodling it out. If not, just keep rotating for TDC on each cylinder then set the valves for that cylinder. Retorque depends on the type of head gasket you use. Check the instructions that came with the gasket. Shouldn't be necessary to re-set the valve lash when hot -- assuming the .027 spec you got is a cold spec. You can use thick break in lube on the tappets or any wear part. Lots of different brands available; in a pinch, use STP.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
