414 motor-combine to 966 tractor ?
Posted by Larry B on May 01, 2003 at 17:39:30 from (216.240.78.20):
Helped out putting a 414 motor off a combine into a 966. Are the injector pumps governers set different on a combine than on a tractor? Low rpm the combine motor will not under load pickup rpm,s. Do we need to put the pump of the old motor on the motor out of the combine or is there something wrong with the pump off the combine?
Post A Followup
: Re: 414 motor-combine to 966 tractor ?
