Re: What is the best way to flush a transmission out out a non running tractor thats full of water dirt and everything but hytran?
Posted by Bob M on May 02, 2003 at 06:58:11 from (165.170.128.65):
In Reply to: What is the best way to flush a transmission out out a non running tractor thats full of water dirt and everything but hytran? posted by big red 1 on May 02, 2003 at 06:43:20:
Your plan sounds good, only I'd leave the spark plugs in. Instead simply block the clutch pedal down before you pull - so the motor doesn't spin and so the tranny is not under load. Then pull the tractor both forward and backward several times. Do this with the PTO engaged, and with the gear lever both in a forward gear and in reverse in order to get things inside the tranny as stirred up as possible. Then immediately pull the drain plug and let it sit for a day or two, or until stuff stops dripping from the drain. You'll be amazed what'll come out!!
Home
| Forums
Today's Featured Article -
Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
