Re: H Governor problems
Posted by Wayne Swenson on May 02, 2003 at 20:03:00 from (66.228.234.21):
In Reply to: H Governor problems posted by Phil R on May 02, 2003 at 08:04:18:
Most likely a part of the counterweight is broken off. The weights resist the pull of the governor spring so if they are not functioning properly, the engine will rev much higher than it should.
If possible look at the parts of a good governor and compare with yours. Otherwise take it apart & replace what is needed.
A parts book and service manual will be a great help.
Good luck.
Post A Followup
: Re: Re: H Governor problems
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
