Re: tractor won't run unless it has full chock
Posted by Haas on May 03, 2003 at 08:21:26 from (166.72.245.85):
In Reply to: tractor won't run unless it has full chock posted by Jim in Canada on May 03, 2003 at 00:41:56:
If full choke is required to get the tractor to run, you may have a leak in the intake manifold between the carb and the engine. Could be either a leaking gasket, or a crack or hole in the manifold. If air is leaking in, it means you have to choke to make the mixture richer to compensate.
Post A Followup
: Re: Re: tractor won't run unless it has full chock
