Re: Re: H lift-all noise
Posted by John on May 06, 2003 at 05:22:34 from (192.233.162.110):
In Reply to: Re: H lift-all noise posted by Gary-Miss on May 05, 2003 at 19:18:19:
Thanks Guys!!! My lift-all is tight, new 6 qt. of Hytran in it, the only thing I did was take that drive coupling off to replace the trans side seal. When I put the coupling back in, it is now a little loose. The lift-all doesn't make any noise when the tractor is running, only when I pulled the control rod (No cylinder attached).
Post A Followup
: Re: Re: Re: H lift-all noise
