Re: Re: Carburetor Confusion on an H
Posted by Fred KS on May 06, 2003 at 05:45:06 from (198.26.125.13):
In Reply to: Re: Carburetor Confusion on an H posted by Zonie on May 05, 2003 at 21:45:03:
I knew that the original distillate carburetor had a drain cock, but after 50+ years someone could have broken the drain cock and replaced it with a plug. Or, a drain cock could have been added to a gasoline carburetor in order to easily drain the gas from the carburetor for seasonal storage.
And like you say, I'll have a mess if I mix the parts, which is what I'm trying to avoid. Thanks for your info.
Fred
Post A Followup
: Re: Re: Re: Carburetor Confusion on an H
