Re: Carburetor Confusion on an H
Posted by Zonie on May 05, 2003 at 21:45:03 from (172.153.29.15):
In Reply to: Carburetor Confusion on an H posted by Fred KS on May 05, 2003 at 20:01:27:
Fred,
I have both a distillate carb and a gasoline carb and the only outward appearance differance is the distillate carb has the drain cock on it and the gas carb just has a pipe plug where the drain is on the distillate carb.
I do know that mixing parts from the 2 will cause my tractor to run like @#$%!
X1 is deffinately a Gasoline only tractor.
Post A Followup
: Re: Re: Carburetor Confusion on an H
