Re: IH 1 bottom plow for Farmall A Tractor
Posted by Haas on May 10, 2003 at 18:25:51 from (166.72.245.233):
In Reply to: IH 1 bottom plow for Farmall A Tractor posted by Paul Johnson on May 10, 2003 at 14:56:45:
I'm assuming you have a one bottom turning plow. The part that is usually missing is the one that controls the tilt of the plow and goes to the front rockshaft arm if you have a super A. To mount the plow, first take the drawbar off, turn it around and remount it facing to the front. Use the mounting holes in the front of the final drive, not the ones at the back where the drawbar usually mounts. Adjust the drawbar to it's lowest position. If you have the mechanism to control the pitch(front to back tilt), that is attached from the drawbar tothe front rockshaft. The plow should have a set of two big springs on the front of the beam with a heavy hinge plate with two holes to match the holes in the drawbar. Bolt the plate to the drawbar so that the outside edge of the bottom is about even with the inside edge of the rear tire. Attach the lifting chain to the rear rockshaft arm. You should then be ready to plow. Takes a couple of furrows to get going. The tractor wheel needs to be in the furrow to do the best job and of course starting out you don't have that. If the plow won't go in, there are some other adjustments that can be made at the hitch to change side to side tilt and help in getting going. The bolts that attach the hitch parts to the beam are eccentrics and can be rotated to change the side to side tilt. The plow bottom should be approximately level when the tractor wheels are in the furrow. If you want to fine tune that adjustment, jack up the land side wheels (or drive up on blocks) to plowing depth, let the plow down on the ground and adjust so the bottom is level to the ground.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
