Re: F-14 temp gauge
Posted by ET on May 11, 2003 at 06:27:37 from (64.19.91.167):
In Reply to: F-14 temp gauge posted by Dan in Ore on May 10, 2003 at 21:31:14:
I have an F12 with a tempature gauge on it. The lower water pipe seems to be a poor place for the temp. bulb. Coolant right out of the radiator is not very warm. The only way I get a reading is to run with the shutters about closed when I'm working the tractor hard, like plowing. Has anyone else noticed this?
Post A Followup
: Re: Re: F-14 temp gauge
