Re: removing fast hitch on IH 140
Posted by Hugh MacKay on May 12, 2003 at 09:32:54 from (64.228.11.34):
In Reply to: removing fast hitch on IH 140 posted by mark on May 12, 2003 at 07:14:47:
Mark: You don't have to remove the hitch to install the sickle mower. You may need some washers behind one of the bolt holes at the back if mower has ever beem on a tractor with standard drawbar. Other than that you just remove linkage at front of fast hitch and front end of hitch pins up to a stub under the platform. Stub under platform has same end and is same size as shaft going to your rockshaft.
Post A Followup
: Re: Re: removing fast hitch on IH 140
