H liftall
Posted by jeff in pa on May 13, 2003 at 06:50:16 from (63.174.30.178):
i am going to drop my liftall to replace a leaking drive seal.
i assume i will need to split the pump from the reservoir. is there anything i should be careful about when doing that? (will anything come flying out?)
Would anyone recommend having the pump re-built to produce the higher pressure while i have it out? i run a loader and three point with no other problems than the leak.
Also,is there anything else i should check on the tractor while i have the pump out of the way? clutch etc...
thanks in advance.
Post A Followup
: Re: H liftall
