Re: H liftall
Posted by Scott Swanson on May 13, 2003 at 08:16:18 from (209.180.31.9):
In Reply to: H liftall posted by jeff in pa on May 13, 2003 at 06:50:16:
Pull the Belt Pulley assembly and check the input shaft for wear and play. The pilot bearing and seals are easy to replace and will improve the health of your tractor. Disconnect the Clutch drive shaft from the tranny coupling and remove the cap crew that holds the coupling in the tranny shaft. A worn pilot bearing is easy to see by removing the belt pulley assembly and wiggling the gears. The 4th/5th sliding gear is right there to inspect. Be sure to dump out the accumulated water in the belt pulley assembly and remember to add additional oil when you replace it. You might want to replace the upper and lower oil seals on both the input shaft and the countershaft. Be careful taking off the nut/driver that spins the belly pump. I had to use a pipe wrench and a high lift to get mine off.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
