Re: SuperA it started, but I need help.
Posted by Dan on May 14, 2003 at 19:34:37 from (66.230.21.235):
In Reply to: SuperA it started, but I need help. posted by Reddog on May 14, 2003 at 19:10:09:
Sorry I don't know much about the thermosiphons. My super c has a 180 thermostat and a water pump. I had to rig a modern type thermostat into it with a couple of copper spacers I cut from a piece of pipe and a big snap ring. I couldn't find an original thermostat anywhere. Do you know what temp it is at? I wouldn't think it should get over 180 sitting there idling. Mine won't even get over 160 till I work it mowing or something then it settles in right at 180.I got a stanley laser temp gage at the hardware store for under 50 dollars. I use it all the time for checking cooling systems and I can even find lean or rich cylinders with it just by putting the beam on the exh manifold and comparing them. It is pretty neat. A cheap candy thermometer at the grocery store works too though.
The surging problem sounds like a governor spring. I think it is called a dampener spring but not sure. It's the one on top of the governor for mine. I think yours is about the same.I worked on so many tractors over the years and still can't name all these parts. It sounds to me like it is misadjusted. Do you have an I&T manual? It tells how to adjust it right.
Post A Followup
: Re: Re: SuperA it started, but I need help.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
