Re: H seals
Posted by Fred KS on May 16, 2003 at 18:53:19 from (64.39.205.237):
In Reply to: H seals posted by mike in PA on May 16, 2003 at 10:12:50:
Mike,
My fault. I saw that you were talking about an H after I posted last response.
If your talking about the Bull Pinion and Brake Shaft seal there are two part numbers. For tractor serial numbers 70828 to 73939, the part number is "58154 D". For serial nimbers 73940 to 391357, the part number is "63090 D". This is a small seal that looks like a washer.
If your talking about the Bull Pinion Shaft Oil Seal, the part number is "48498 D". This is a larger seal, about 3" in diameter.
The seal on the brake/clutch pedal pivot shaft is part number "360076 R91"
Hope this helps.
Fred KS
Post A Followup
: Re: Re: H seals
