Re: Re: P.T.O. / Belt pulley attachment question for an A
Posted by Steve T on May 18, 2003 at 06:58:16 from (216.187.161.4):
In Reply to: Re: P.T.O. / Belt pulley attachment question for an A posted by Hugh MacKay on May 17, 2003 at 12:44:33:
I have pulled 3 different transmissions apart that range from 1940 (the one im restoring) to 1945. All 3 transmission cases are slightly different from each other. The early A PTO/ belt pulley attachments are cast and built way different then the latter (1942? and up?) castings and are not interechangable unless both the PTO and Pulley box's are changed as one unit. I dont know about the SA as I dont have any books on that one.any chance you could send me a scan of the pulley box? Thanks for your time.
Steve T
Post A Followup
: Re: Re: Re: P.T.O. / Belt pulley attachment question for an A
