Farmall Tractors Discussion Board
Re: Magneto problems
Posted by Geezer on September 17, 1999 at 08:17:35 from (216.161.105.47):
In Reply to: Magneto problems posted by Vernon Graham on September 13, 1999 at 23:09:17:
Check your grounding switch first.Impulse coupling also. Then replace ign. coil.
Post a Followup
: Re: Re: Magneto problems
