Re: I hate starter trouble!
Posted by Hugh MacKay on May 21, 2003 at 03:16:17 from (216.208.58.137):
In Reply to: I hate starter trouble! posted by Boomer on May 20, 2003 at 18:29:24:
Boomer: Sounds to me as though you are using the old type bendix or starter drive You put one of the new clutch starter drives in there it should solve most problems. It however will not heal a bruised up flywheel ring gear.
Post A Followup
: Re: Re: I hate starter trouble!
