Setting the govenor on an A
Posted by mk on May 21, 2003 at 06:01:14 from (169.244.70.146):
Hi, I have a '47 A and I have a small problem with the
throttle. The throttle advance lever (I guess that's what you
would call it) is a little out of wack. Right now low idle is
when the lever is about half way (almost in line with the
steering post) and I can't move it back any further then
that. High throttle is about an inch past the last tooth on
the bracket. I would like to get it set up so the lever uses
the full swing. I looked at my BN and my other A (both
which use the full swing), but I can't seem to figure out how
it set it. I know it's in the govenor, that I can see. Every
thing runs well, but it's annoying.
Thanks,
mk
Post A Followup
: Re: Setting the govenor on an A
