Re: IH 884 hydraulic oil foaming TA
Posted by ih_bug on May 26, 2003 at 20:34:32 from (66.46.141.58):
In Reply to: IH 884 hydraulic oil foaming TA posted by Dick C on May 26, 2003 at 07:05:00:
if the TA is slipping in low that means that your sprag clutch is slipping and she will have to be split to fix it no oil pressure needed for low , either the plates are out in high (likely) or you have no oil pressure to lock up the clutch pack.
does this tractor have a loader on it? if so where is the return line dumped? it is supposed to go in a plug behind the right rear tire in the bottom of the transmission not be dumped in the fill hole in the back . if dumped in the fill hole will cause foaming because of air mixed with oil.
Post A Followup
: Re: Re: IH 884 hydraulic oil foaming TA
