Re: Re: How to perserve a TA on IH986?
Posted by Shawn on May 31, 2003 at 15:04:38 from (205.188.209.140):
In Reply to: Re: How to perserve a TA on IH986? posted by Hugh MacKay on May 30, 2003 at 20:22:45:
Hugh I have a few TA questions. I have only run a couple TA tractors, most time on a 504. I assume its a clutch to engage another shaft in the rear. If so it would be just a normal adjustment to service & would last awhile if not abused. I also saw about not using a TA as a "brake" in an above post, the 504 would free wheel if put in low side downhill, but I did see a company at the farm science review in Columbus Ohio about 15-20 yrs ago that claimed their replacement assembly would work both directions & could be used as a downshift to hold the tractor back. Any info?
Post A Followup
: Re: Re: Re: How to perserve a TA on IH986?
