Re: Re: Re: C runs Poorly
Posted by Shawn on June 01, 2003 at 13:24:22 from (152.163.253.102):
In Reply to: Re: Re: C runs Poorly posted by Carm on June 01, 2003 at 13:09:50:
Ok the easy fix didnt help, sorry. Try checking your points, gap & condition, then also your plugs. your plugs should give you a look at the situation. They should have a light gray color to the insulator. All plugs should show the same coloration. A dry black carbon is a little rich. Wet, smelling of gas is fuel fouled. You didnt mention any blue smoke so oil foul is probably out. Maybe try fresh plugs, be sure gap is correct.
Post A Followup
: Re: Re: Re: Re: C runs Poorly
