Re: farmall h pto shaft
Posted by rustyfarmall on June 02, 2003 at 18:12:43 from (207.32.13.225):
In Reply to: farmall h pto shaft posted by Wayne B on June 02, 2003 at 16:59:23:
Just unbolt it at the rear of the tractor, I think there are 4 bolts? maybe 5, and then the entire unit will come out, including the long shaft that goes to the front of the transmission.
The unit may be stuck with the gasket where it mounts to the rear end, but a little gentle prying should get it free, be careful not to damage the shims that are in there with the gasket.
Also, you will want to set a bucket under the tractor to catch the oil that will come out. If you can park the tractor so it is headed slighty down hill, you won't lose as much oil. Not too complicated of an operation. Have fun!
Post A Followup
: Re: Re: farmall h pto shaft
