Re: SMTA Hydraulics
Posted by Farmalldan on June 03, 2003 at 09:51:15 from (64.154.26.248):
In Reply to: SMTA Hydraulics posted by Ernie Bob on June 02, 2003 at 22:44:24:
Ernie,Are you using the optional four way remote valve under the fuel tank and ahead of the Liftall unit for your remotes? If so, do you have the Liftall rod latched back. Your remotes will not work unless flow through the Liftall unit is blocked. When cold, you may have enough flow restriction to develop some pressure and make things move. Otherwise, I suspect Bob is right.
Post A Followup
: Re: Re: SMTA Hydraulics
